new need help plzsl
donn94
I got a 85 force in it is stalling at wot or sometime it want even crank
I did a compression test and spark test next im going to take carb off but dont no where start
I have pics but it want let me upload files to big
the compression test was 120 on top mid was 115 bottom was 115
scottmm73
Re: new need help plzsl
If you are adding a pic by url be sure to deselect "Retrieve remote file and reference locally".
donn94
thanks for the reply trying to upload from cp took pics with my phone
emoney
I do pics through Photobucket. It's a lot easier.
Time to check those fuel lines and pull off that fuel pump cover and take a look at the diaphram. It it's cracked or flaky, relace it. Same for the hoses because it won't do any good to clean carbs if that's not done.
donn94
im lose i dont no where the fuel diaphragm is i got a real old manual its show me but its not there
emoney
Follow that fuel line from the carbs back towards your motor's block. It should go into the fuel pump. A flathead screwdriver to take off and it's under there.
jerryjerry05
Boats . net find your motor then the year.
The parts diagrams will help take it apart.
I see the starter is still engaged.
A VERY SMALL touch of grease on the worm screw under the bendix.Did I say VERY SMALL??
Too much and you'll be buying a new bendix.
The 1988/85 shows a better diagram of the fuel pump.
Replace all the hoses.Squeezie too.
Rebuild the fuel pump.
Clean the carbs.
When you remove the air screws remember where they were set and post that.
Check tank for water and make sure the tank vent line is clear.
stubtail
You have a disconnected hose laying in the lower cowl. Trace it back - where is the other end connected?
donn94
thanks all for the help will give update
emoney
Pics are too small to see. For me at least.
donn94
sry about pics but i need to rebuild pump it was all crack out thanks for the help will update as soon as i get pump
donn94
i did not no that gasket was between carbs an intake cover is that right.
Quick ? when i buy the fuel diaphragm do the screen, gasket, diaphragm gasket come with it Thanks
emoney
If it's coming as a "Fuel Pump Rebuild Kit" it should. I'd say to ask the place you're ordering it from to be sure.
donn94
thanks all for the help rebuild the pump choke fire right up. Now i notice a gas leak right here8801d611.jpg
well i think it gas
thanks
jerryjerry05
Stub,the hose is the return line from the bottom of the carb cover.
The leak you see is probably unburned gas/oil from tilting the motor.
Check the pump and carbs while it's running.
They shouldn't have any drips while running.
Get a better camera,the pics are way small!!
