New Merc starter problem
eastmanace
Hey guys.....I have a mid 90's Merc 25 electric start that I just aquired. After a carb rebuid, I changed out the starter (AARCO). Things worked fine for the first 25 or so starts, but now when the key is engaged all I get is the solinoid click. If I manually rotate the starter shaft ( clockwise) the engine fires right up. Things work normally for a few start cycles and then the same problem occurs. What gives? I thought I'd ask here before assuming the starter was bad from the supplier. Any help appreciated.
JB
Re: New Merc starter problem
Go to "Outboard won't start" in the Engine FAQs, ace. Do the starter circuit troubleshooting.
Let us know what you find.
