310jag
- May 13, 2009
- 2
Hey gang,
New to the site, and wanted to start posting. I've recently acquired a 1983 built 17' Warrior, with a 1984 built Johnson 50hp (J50BELCRM). My grandfather had it since new, and used it very often every year up until four years ago. It was covered and stored outside, but very well maintained. It's mine now, and despite being dirty, it appears to be in good shape. Mechanically it's good, but I still plan on doing the usual tune up and fluid change.
I've found a couple cracks and a soft spot that I'm really loosing sleep over. I'm hoping my fun is not sunk before I even get it into the water. I've attached some pics that hopefully will show their location and severity.
There is a crack on either side, same location, same severity. They are not very visible unless you apply a little bit of pressure to the deck, and then the crack begins to separate. Also, moving towards the stern, on the deck, about 2" before you get to the storage area (where the fuel tank and batteries are), the floor goes soft. I'm assuming this is the result of a rotted stringer or other substructure. Now, I'm not shy about tearing into it, but if it something that just isn't worth fixing, I need to know. Can I lay some new fiberglass/resin into these areas to reinforce them and help them from getting worse?
I hope you guys can give me some guidance on this.
Also keep in mind, in the last pic, I'm applying a little pressure to the deck to help show the crack.
Any feedback is greatly appreciated, thanks gang!
-Wes
-Wes
