New layer of resined 1708 on older layer
wallybme
Can you put a new layer of resined 1708 on an older layer? I just want to seal some of the cracks. Do I have to resand the older layer?
Woodonglass
Re: New layer of resined 1708 on older layer
I'd recommend always sanding with a minimum of 60 grit and wiping down with acetone before applying any new resin and glass over old glass. Well.... How old is this glass???:rolleyes:
alligatorgars
Ive seen a few 25 yrs plus old boats being restored for offshore use. Is doing this asking for trouble considering the hull is only as strong as the poly that was rolled out 25 years ago? Will this poly become brittle and prone to hull splits? Putting around sweet water old man style is one thing but the beating big water can give is relentless on any hull. Ive always wondered what the shelf life was on these poly resin glass boats. Would adding a layer of 1708 increase the structural strength of these hulls without adding to much weight?
Woodonglass
That's a question that Yacht Doctor would be best qualified to answer. You might send him a PM.
