Purchased a Landau 14 foot boat with Johnson J35EL CND, brought it home today and checked the spark plugs. Found 2 different sizes of plugs. That might explain why he said it ran rough last time out on the water(last summer). That and there is Ice in the fuel tank. He did say not to try and use the current fuel in the tank. Current registration is 2021 so wonder about being on the water last summer with expired by a year registration.
Appears that the Champion L77J4 would be the correct plug for this engine.
I would have found this if I had ask to check for compression before buying.
It is remote steering, has a 40 pound trust troller on the front, but no batteries. So should I buy a deep cycle and a starting battery or can I get buy with just one? He said it had a carb. leak and he had purchased a gasket kit. He had a package of cork gasket material, I will order a carb kit and check out the jets and re-gasket the carb. Also watched a video on checking/replacing the water pump, looks simple enough.
