Normally, factory setup on a Ford based mercruiser the pcv valve in the rocker cover is routed to the carburetor base (below the throttle plates).
In your case with a new carb, it's unknown if the base has a port for the pcv valve line. Your picture shows a suitable location to connect the pcv valve line, just make sure there are no kinks and you'll be fine
