New here Having transom replacement trouble
nickinfl
No Title
I believe you are correct in that I can just remove those panels, they are only connected by rivets at the top and to the transom brace at the bottom.
GA_Boater
Sometime boxes, for lack of a better name, like you have are used to contain flotation foam. Maybe not because there is an access hole for battery cable, fuel hose, etc. in the left one.
If the front or better yet sides can be removed, the nuts will be staring you in the face.
nickinfl
It's one piece on each side. Should get them out easily. There is foam in there, but it's 40 years old and I'll replace it. I appreciate your help.
GA Boater, There are still bolts going through the transom that I have no access to because the splashwell is in the way. It seems ridiculous to have to remove the entire splashwell to change the transom.
you have to think like the manufacturer did
yes the splashwell has to come out. not all of mirrocraft boats got a splashwell. the splashwell was added after the transom was put in. the same basic hull went as either a pure fishing boat or a fish-n-ski
remove the splashwell (a bunch of rivets) and continue to remove the bolts thru the knee brace
GA_Boater
Remove the boxes/panesl before deciding if the splashwell needs to be removed.
