New guy, floor repair questions
Racer223
And just so you don't think I'm a total wanker, here's some other progress I made:
Back in August I pulled all the cushions out and took them completely apart. Turned out they used crap plywood and regular stapes and when it started falling apart someone just poured caulking into every hole. Once I cleaned up the sealer and separated the foam, vinyl and plywood I realized that everything except the plywood is in good shape (aside from the sealant residue) and it's not a difficult fix. I bought few pieces of Azek of various thickness and cut all the cushion bottoms out of it, bought marine grade staples and just put it all back together, came out better than I expected.
I also did some work on the trailer, the bunk board supports were too short and getting bent at the bottom, so we made some new ones using square tube, milled out the slots and left the bottom a solid so it doesn't spread again, new carpeted boards, wider rollers and improvised guide-ons made form what I had on hand, just need to add the bunks or put some PVC pipe over them so they don't scratch the boat.
Can't wait to get all this done so I can get out on the water soon
airshot
Fiberglass boats back in those days have a wooden skeleton over which the fiberglass is layed. If you remove the skeleton, the fiberglass will give and cave in !! Boats rot from the bottom up....this means if your floors are rotten, the skeleton under the floor is even worse ! All that rotten wood needs to be cut out and removed, then new wood needs to be glass bedded the glasses over to get the skeleton strength back or your hull will crack and crumble and your boat will sink ! Wish I had better news, but your boat is an accident looking for a place to happen without serious and expensive work !
Racer223
I have drilled a hole in the floor with holesaw and found ZERO ROT, I'm not willing to perform an autopsy on a "living patient" just to prove there was no cancer, just looking for an ideas what kind of foam and where to get it, this is just to fill a void that is 1" deep on the sides where plywood ends, once again, THERE IS NO ROT, looks like fiberglass sagged and cracked where plywood ends, you can see the cut made in the plywood that was there when I opened the floor
airshot
The rotten wood stringers and supports are enclosed inside the fiberglass. Your floor is buckling because the skeleton inside the fiberglass is rotted. Being a trihull, they used plywood covered in fiberglass with a chopper gun which added little strength to the hull. Your boat, your call, but I would not take passengers onboard if you use it as is.
Baylinerchuck
You have to be careful when pouring foam in a cavity like that as it could push that floor up and cause a bigger issue. You would be better off filling the crack with thickened reinforced resin, grinding down to good clean fiberglass, then doing a couple layups of CSM tying the repair into the gunwale. If you do decide to throw some foam at it anyway, I would use the 4lb pour in foam since the repair is structural. You would still need to go over everything with a few layups of glass.
Since you do have some holes opened up in the floor, make sure you look at those stringers and substructure. Look as close to the transom as possible. Make sure you check the transom. Any hole you drill as an inspection can be filled with reinforced thickened resin, (hairy peanut butter). You don’t need to hole saw massive holes as they are harder to fill, 3/8” drill bits will tell the story clear enough.
Good luck, and please keep updating as you proceed.
Racer223
Thanks!
I can stick my head under that tray in front of the engine and see the back of transom and drain plug, looks good to me, no bubbling or anything like that. those 2 large holes I drilled upfront was for ventilation while it's drying out, wanted to move air through the whole hull.
I have a friend with a high end camera we use to inspect the cylinders and other tight spaces so I'll drill holes that are just big enough for the camera to fit through and inspect the whole floor if I can.
I was thinking maybe I should remove that whole corner area that sagged and instead of trying to force the foam inside it just start over with some plywood and fiberglass, would be easier to support it rather than trying to force something in? it doesn't seem to be sructural as it's only a think later of fiberglass and whole lot of some kind of greenish filler (bondo?)
airshot
Thanks!
Greenish filler means someone has tried to cover up the rotted wood inside the fiberglass. In those days, it was thought that fiberglass was water proof, but it is not, only the gel coat makes it waterproof. The glass material over time absorbs water and turns the skeletal wood rotten. Drill some holes just deep enough to get to the wood and you will find some mushy wood if there is any left.
Baylinerchuck
Thanks!
Just looking at it unfortunately is not good enough. The structure of our older boats is mainly plywood encapsulated with fiberglass. The plywood provided the structure as the fiberglass is pretty thin. Drill a test hole low on the transom from the inside into the plywood but not all the way through the boat. Examine the chips for wet wood or rot. If none, fill the hole with some filler and move on.
If you take care of the crack with hairy PB and laid up glass it’ll be strong. Cover it with carpet and go boating. No need to start tearing out plywood unless you’re going to do a full restoration. Like others have stated, boats rot from the bottom up.
Racer223
filler only covers the fiberglass, which just just hangs over an empty cavity, there is no wood under it, doesn't look like there ever was anything there
Racer223
I'm definitely not restoring this, just need it to float, not a beauty contest with all the million dollar boats in this lake.
I'll drill some holes and check the wood chips.
at 14' this boat is not going anywhere near rough seas, just something to get out on the water, usually to the nearest sandbar to chill or across the lake (1/2 mile) to watch sunset
Racer223
That’s a great picture. Enjoy it!!
Thanks!
I wasn't a fan of boats, only got this one because my shoulder was gone and I couldn't use the canoe anymore (my canoe is bigger then this tub)
Was planning to get rid of it this year since I finally had my shoulder repaired, but having ability to go out on the lake almost every night and enjoy moments like this with a minimal effort has changed my mind, so I'm keeping it!
Racer223
Long overdue update:
finally caught up with house and work and got to work on the boat late June, sanding the floor I noticed 4 patched holes, someone drilled 3" holes, poured foam in and then patched them up with fairing compound... definitely a hack job, repair was so thin it just popped out
I made round plugs out of 3/4 ply and used resin and 1708 cloth to patch the holes. drilled or ground through at every dark spot on the floor but it was either some rust from old screws or knot in the plywood, patched it all with some 1708 and structural putty, then put down a single layer of 1708 over the entire floor, and then some cheap Amazon faux teak foam on top.
Stripped most of the old upholstery from the gunnels and rotten plywood that was holding it up, sanded, patched the holes with structural putty and rolled couple coats of gelcoat over it,. Put down some 1/4 round mahogany trim where the floor meets the gunnel so the foam doesn't lift up (Amazon, so I don't expect much of it) Added a large base to the chair because the screws were pulling out if I was leaning on it hard. I don't have any pics of the finished interior, pic above is about 75% done. Also rewired the whole thing with marine grade wire, solder and heat shrink, replaced all the rotten wires and crimps, also installed battery tray, no more bouncing battery.
Also finally named it.
It looks great, works pissah and we've been out on the lake every free day we had this month, chasing sunsets and loons, with an occasional bold eagle sighting.
Also it's so light my TDI barely noticed that it had something in tow. I only used the VW to bring it up to Maine, we use the truck to launch it because it has 4x4 in case ramp is slippery.
