New fuel pump install problems
bs4690
Quite a specific question but here it goes. Just looking for some input on a fuel pump I recently bought. It is a sierra style mechanical fuel pump part# 18-7278 for my 1986 mercruiser 3.0 140hp. My old fuel pump did pump fuel but was all gummed up with junk and had a small tear in the middle gasket so I took the liberty of replacing it as well as cleaning my gas tank as best I could. Only problem is the new one isn't working.....
I noticed there was a slight play in the new fuel pump lever that gets pushed in by the cam lobe before I installed it, but thought nothing of it. It works fine by hand at the bench once you get passed the "play" in the lever but when installed I get zero fuel even when I prime with a outboard fuel line bubble connected to a portable gas can with new clean gas. The old fuel pump had zero play in the lever and had 2 gaskets between it an the engine block. I'm guessing the 2 gaskets were used as a sort of spacer to decrease the fuel psi on the old pump so i tried only using 1 gasket on the new pump. Still nothing. So I took apart the new pump to inspect the diaphragm and noticed that when apart there was no play in the lever. When compared to the old pump the spring underneath the diaphragm on the new is much longer holding the diaphragm up much higher. This is causing the lever to have play when reassembled.
I'm assuming the play in the lever is too much and the cam lob can press it in far enough to initiate a pump. I've ruled out a vacuum leak by checking and rechecking thread fittings and by using new fuel lines. Soooo....faulty fuel pump? right?
Any input is helpful! Thanks!
ktbarrentine
Re: New fuel pump install problems
Will just throw in my two cents.... IMHO, Sierra mechanical fuel pumps are crap. Made in China. My replacement (put in a 1990 5.0L mercruiser) lasted a whopping 7.5 engine hours before the diapragm separated from the operating shaft (actually cracked apart at the joint). Replaced it with an OEM fuel pump at just a tad more cost and all is well.
Failproof
Any slight play in the lever should be taken out when bolting to engine. The rod compresses the lever, the counter springs keep pressure on the lever, rod, then cam lobe. Do you have to push the pump on/ pull it the last little bit with the bolts?
bs4690
Yes the cam lobe is at its lowest position and the bolts push the pump and compress the lever slighty at the last turns of the bolts. However when I compare old vs. new pump, the old pump starts to compress the lever when it is much further from the block, probably starts to compress the lever with a couple turns left compared to 1/2 to 3/4 turns with the new. I'm quite angry and hope the online retailer will still accept the return/exchange.
