Re: New build crackerbox
First coat of primer I will sand this down with 600 paper and do two more coats and sand again.
First coat of paint "roll and tipped" I will do another 3 or 4 coats with a light sanding in between then on the last coat I will sand it with 800, 1000, 1500, 2000, wet and then rubbing compound. There is a white waterline around where I think it should be but it may need adjusting when I get her in the water.
Drilled out the hole for the prop shaft today, I had been putting it off a bit as there is no room for a mistake here.The angle was worked out from the engine setup and then marked on a bit of scrap wood where I drilled out a hole to take the extension bar holding the 2" bit, I also put a block of wood on the keel inside and out the same angle as the bit to give the tip a starting point and so it would not start walking when it came through.
All in all it went well except for the sawdust and smoke under the boat from drilling a 10" x 2" hole in mahogany while lying on your back, in the end it came out spot on target
I now have to epoxy in a fiberglass tube to seal it up and then cut it down to size.
