I just bought a new Tahoe Q7i (bowrider) this past August and its everything I wanted in a boat, so far. The only thing that's bugging me is that I don't get the chance to use it enough.
I'm currently having problems in selecting the right prop, though. I want more speed at the same RPM's. Switched to a 21p Enertia (Great Prop!) and achieved 60+ mph. But, my RPM's went down below Merc's specs. Will have to get a lower pitch prop and hope I don't lose the top end. I'll be selling the 21p prop on Ebay soon, if anyone is interested.
Rich
Hey thanks for that info etransfer. In doing a little more research with the folks at Mercury, they recommended that I go with the 18 pitch Enertia. Like you stated, I'll probably lose some MPH but, will be in higher RPM range with a light load and lower range with full load.
Well, with the 21" I was only getting 4,400 rpm's (200 less than Merc specs). If reducing pitch increases rpm's by 200 per one inch drop in pitch, I would only get 4,600 rpm's with the 20". My 260 hp Alpha One range is 4600 - 5000 rpm's. I want to achieve the max rpm so when I do have a full load, the rpm's will still be in the recommended rpm range.
Speed limit?...What speed limit?
That's why the Hustler 21" is a good backup for cruising and it only takes
about 2 minutes to change the prop out.
If I go out with one or two other people I use the Hustler then change back to
the Enertia for a full load and tubing etc..
Just got back from testing the 18p...Another nice prop! I got 58 mph at 5,000 rpm's WOT & full trim. Didn't notice the 3 mph loss at all. This prop responds to steering wheel turns very well and holds the turns without blowing out. It was a little bit slower than the 21p out of the hole though.
Rich
Yup...Now I'm shopping for a four blade prop for good hole shots for wakeboarding and skiing...Any recommendations? Thinking about a Vensura but after reading your post, I'm considering aluminum.
You're lucky...I have to tow my boat 45 minutes to the nearest lake and 15 minutes to the bay. I haven't taken it in the bay yet, though. Kinda reluctant to take into saltwater. I just got the 4 blade Revolution off Ebay and I'll let you know how it performs.
ET, what are you turning (RPM's) with that 19"?
