v1_0
- Aug 27, 2007
- 575
Re: New boat needs interior done, any tips??
I'm getting ready to do this sort of thing and my plan is as follows:
1. Get the plywood backing cut & shaped.
2. Drill holes where I am going to put *bolts* through the wood into the fiberglass.
3. Put an aluminum (or plywood) strip on the other side of the fiberglass - so that it will create a 'sandwich'. Use the holes drilled in the seat/side panel backing as the pattern to drill the holes into the strip.
4. Resin/Glass the plywood backing (and the strip if I end up using plywood) - taking care to glue the bolts in place (and leave holes open).
5. Do the vinyl foam thing on the plywood backing.
I'm hoping that, if I've done everything right, there are no holes in the vinyl / foam because they are placed ontop of the bolts. The sides would be installed by alligning the bolts in them with the pre-drilled holes in the boat's fiberglass and the backing strips, then a nut/washer (lock washer) on the bolt.
I have given thought to just glassing/epoxying a plywood backing strip to the inside of the cap first, then doing the predrilling. That may make installation a bit easier in that I only have one moving thing (side panel) to wrestle with instead of two (side panel and backing).
The backing strip should act like a big washer, in that it would distribute the pressure more evenly, and be less likely to have local 'breakage' like the fiberglass.
OK ... I am brand new to this site ... so thanks in advance for any advice guys!
I have a 1986 Bayliner Capri. Interior is shot. Going to reupholster the seats and side panels. How the heck do you re-attach the side panels to the sides of the boat? I had to basically rip the panels out because they were screwed into the fiberglass ... but the screws were underneath the vinyl and foam with no access without tearing through the vinyl and foam. Any suggestions from someone who may have done this before?
