Re: New boat needs interior done, any tips??
OK ... I am brand new to this site ... so thanks in advance for any advice guys!
I have a 1986 Bayliner Capri. Interior is shot. Going to reupholster the seats and side panels. How the heck do you re-attach the side panels to the sides of the boat? I had to basically rip the panels out because they were screwed into the fiberglass ... but the screws were underneath the vinyl and foam with no access without tearing through the vinyl and foam. Any suggestions from someone who may have done this before?
Welcome!!!!
So i did my first interior on my first boat for the first time. I used some cupped washers from the hard ware store and some deck screws to attache my panels. They worked great. They are stainless steel so they dont rust, the cup in the washers allows for the head of the screw to seet into it, and they are way cheeper then getting the capped washers that are tipically used in older boat interior.
When you do your panels, use a little thinner wood then you think you should. I used 1/2" thinking that was to thin, but in the end I wish I had used 1/4" on everthing but the main side panels in the aft of the boat. When you chose you matting to use, make sure that anywhere a butt is going to be is soft. I used some closed cell foam that felt soft untill I got the vynal wrapped on it, then it stiffened up a lot. When you get the matting on your backer board, if it is stiffer, make sure to round all edges so that the vynal rolls and flows a little better.
When you attach the panels back into the boat, you will find that you have to go through you backer board first, well that is a no brainer, but then it taked a minute to get into the fiberglass on the boat. Once you get into the fiberglass and have it "threaded" i guess we will call it, back the screw out of both untill they touch each other and the screw it back in. This is what I did and it allowd the panels to be tight in place, but did not put to much strain on the vynal where the cupped washer was.
And to seal things up when installing any panels where they are going to come into contact with water more then the rest, I used some marine sylacon(sp) to seal between the backer board and the vynal, and used a trowl (sp) to smooth it out so that there was not to much build up. I also used a little at the top of the panels that were going vertical to keep water from being able to get behind them.
I hope that this helps some, and like I said, I have only done this once, but I read a lot before I did it and did a test panel to see how things would turn out. Good luck and hope this helps.
