jprice
Thread starter- Joined
- Sep 10, 2009
- 58
So I just purchased a 96 seadoo speedster jet boat. In great condition, and ran great during the test drive.
Took it out today for the first time as the proud new owner.(my first boat, btw)
Cruising around for about half an hour. Then the left engine starts revving higher than the right and I struggle to keep the rpm's the same. Eventually, this high pitched alarm goes off.
Believe it or not, I actually read a good chunk of the owners manual the night before, and remembered that this meant engine overheating.
So I follow the manual instructions to clear the impeller (assuming there was an obstruction), but I can't run it more than 30 seconds before the alarm kicks on again. Finally I find out that I can keep the engines at about 3000rpm without it overheating, and gimp back to the boat ramp at about 12mph.
Once I get it out of the water, I can see that the cable connection for the reversing gate for the left engine has broken, so the gate was basically stuck in the closed position. I'm hoping that this is what would cause the engine to overheat? I don't completely understand the cooling systems for these jet boats other than they need water flowing through them to cool.
Even though the left was stuck in reverse, I was still moving forward, so I'd assume there was still water going through the engine?
Ok, so after my long winded, noobie boater explanation, is the stuck reversing gate the cause of my overheating, or do I have a bigger issue on my hands?
