Re: new boat answer some ?'s
The vibration could come from several places. Start with the basics and take compression first. Assuming that's all good then look at the prop. It might just be out of balance. If that's OK then look at your lower unit. Take the prop off and look at the bearing carrier in the gearcase. Yours may have tabs that hold it in place. If so, you'll see 2 bolts just inside the gearcase. Make sure they're tight.
