"New" 1995 Evinrude 90HP questions
Boatnsteve
Hi all,
I just bought a used pontoon boat from a guy who was in the process of rebuilding it for himself before he decided he had to sell. The boat's previous engine was blown so he bought a 1995 Evinrude 90HP for it. I had a mechanic give it a once over and the only significant thing he found in need of attention was the water pump impeller (big surprise, right? ;)). After replacing that I took it out for it's first run and it performed like a champ. A very thirsty gas sucking champ, but a champ none-the-less.
I've never owned an oil injected 2 cycle motor before, nor have I ever used the controller type that came with it. This is the type with a single leaver with the push button clutch disengage and ignition key push-to-choke. It works fine except pushing forward puts the motor into reverse, pulling backwards goes into forward. Is there any way to change this? If so, how do I do that?
Second thing... how can I be assured that the previous owner, who never put this thing in the water, has the temperature and oil alarms hooked up properly? An alarm saved me from cooking my 4 stroke Honda last week (bad water pump impeller) and therefore I'm very interested in having them work.
I'd ask my mechanic these questions, but it's a new relationship and he's pretty busy now that high summer is here. I'd rather not bother him with stuff I could do with a little knowledge.
Thanks!
Steve
emdsapmgr
Re: "New" 1995 Evinrude 90HP questions
You did not mention what engine you have. That year OMC made both a crossflow type and a looper type 90 hp. Pls post the model number to help us identify just what you have. Perhaps you can post a picture of the control box that you have on the engine. When you first turn the key to on, do you get a short (test) beep out of the control box? If you ground the wires to the head temp switches, you should be a a constant warning horn. If so, your horn should be ok.
Boatnsteve
Ah, two models. I wasn't aware of that. I'll have to grab the info this weekend as I don't have a manual and the boat is 40 minutes away.
I definitely don't get any beeps when I go to start up. Looks like something isn't hooked up correctly or the horn is non-functional.
More info and some pics when I get back from the weekend.
Thanks!!
Steve
