Never have seen a big twin like this one...
joestn89
Hey new to the forum and been looking through pictures and websites trying to find an answer and now I'm here. I've been working on a mid '60s big twin and I think it's around a 35 or 40 horse. Its going on my '73 polar craft that I just completely rebuilt. Its running like garbage though, under no load it revs all the way but in the water it only gets to about 25%. This motor was completely rebuilt before I got it and I know that just by seeing how clean everything is. I cleaned the carb which was spotless, tried fresh gas, and now I'm at ignition because it will also run for a few seconds and then just completely shut off. They points condensers and coils look new. But what I noticed was on the crank where the points ride there is no "removable" cam. They are just riding on the crank and there is a slight hump on the crank but every picture I can find there is a cam there. I'm just trying to figure out if someone got crazy with a file or if this is stock.
F_R
Honorary Supreme Mariner
The cam is normal.
Those parts do not look like new to me. In fact they look scungy. Clean all that mess up and either replace the points or completely remove them and degrease them and polish each contact shiny bright. Set gap to 0.020" when reinstalling.
Condensers may or may not be good.
Coils look ok physically, but are old. May or may not be good.
You ought to polish that shaft shiny bright also. And the taper in the flywheel. Reinstall dry and torque nut to 100-105 foot pounds (important).
joestn89
I set the gap to .020 last night and ran it but I'm still getting a hard miss here and there and it will shut off, everything looks new to me so I was gonna let it fly. I'm gonna check my spark tonight and make sure I have a good blue flame. It does run alot smoother now though the point we're set at like .010 before. I'm gonna run it till it shuts off again and then pop the drain on the fuel bowl just to make sure that fuel pump is pumping/fuel bowling is filling properly. My fuel bowl float was also off and I got that adjusted. Thank you so much
joestn89
And yes we had a slight drizzle last night and I needed to get a picture, don't worry I blew everything out with a air compressor right after .
oldboat1
good if you could find and post a model number. On a mid-60s big twin, you likely have a low speed carb needle at the top. The misfire you are hearing may be a lean sneeze. Open the needle, if you have one, 1 1/2 turns from seated. If the engine will start, let it warm up then adjust for best running. Small adjustments.
joestn89
RXL 10 C
So it's a 1962 28 horse. And ya I have noticed that opening it 1.5 turns will start it. It's running pretty dang good at low speed with the throttle cracked but when I bring the throttle up it starts hitting and sputtering. I did notice something weird though, if I pull off a plug wire while it's running the speed slows down (obviously) and it runs super smooth and that goes for both plug wires. I pulled all of my ignition stuff off tonight and I'm going through everything with my meter. Coils are good, points are clean, and all connections are clean. But I'm hitting everything with some sand paper and making sure I have good connections. The only thing I cant test is the condensers or at least I've never heard of a way to. I'm gotta put that back on and test for vaccum leaks. All the kill switch wires looked good also. Any ideas? I'm a former car and now caterpillar mechanic but this simple little outboard is kicking my tail.
oldboat1
Those buggers run well on only one cylinder -- yours is exceptional, imo, in that it is smooth on either (a good sign). It's also a good sign that it idles well (on both). I'll guess that the lower needle (h.s. needle) might need adjustment. Try 1 turn open from seated, and tweak it slightly leaner when it warms up. Gotta be on the boat for final adjustment.
If throttle plate opens too early the motor will complain violently.----Look into synchronizing throttle and ignition advance.
joestn89
You were just about on the money, I did 1.5 turns on top, and 1 turn on the bottom and it runs pretty well we will see how she does on the water this weekend. It's been idling for about 10 min now and hasn't shut off, still kinda rough though but it is an old motor. And you set the advance so that the roller makes contact at the "T" on the plate right?
oldboat1
Roller should first contact the cam at the mark (throttle plate will begin to open at that point) -- synchronizes timing and carb. That may affect your idle speed a little.
Setting the idle air mix leaner increases rpm when you are looking for the best adjustment (1 1/2 open is an initial setting, and the final may be different). You also have a throttle stop -- think on yours it's the plastic screw down at the bottom of the tower, throttle side. Can set idle speed with that. Should go in and out of gear smoothly without jerking or stalling (about 650 rpm, give or take, in gear -- warmed up and in the water).
