neutral start help
mulli2b
I have a uflex single lever throttle, I installed. Where do I connect the 2 neutral start wires coming from the thottle?
Bill
wire2
Re: neutral start help
Whaddya got?
An outboard system shorts the ignition to ground, an I/O system opens the distributor circuit.
seabob4
Merc and OMC, you'll have 2 yellow w/red stripe wires coming out of the engine harness. One lead to one, the other lead to the other...
seabob4
Whaddya got?
Wire,
That's your kill switch circuit, not neutral safety...
seabob4
Dang! You're right.
On a rare occasion, it has been known to happen...just don't tell my wife! I'M ALWAYS WRONG!...But I love her none the less!
bruceb58
Honorary Supreme Mariner
One of my favorite quotes from the TV show MASH:
"Frank, you are always wrong. That's what's so right about you."
mulli2b
so if i haven't connected the wire yet it should have no issue with me starting the engine? I can't get the engine to start, just keeps cranking,
NYBo
That switch interrupts the starter circuit, not the ignition. Check your kill switch, which DOES interrupt the ignition circuit.
mulli2b
i haven't installed a kill switch. This is a complete modification from the ground up
seabob4
As NYbo stated, the kill switch works by grounding the coil, in the same manner that your ign switch works when you turn it off. Is it possible that the engine has other problems that may keep it from starting? You may want to post a pic of what loose wires you have out of the engine harness behind the helm...
