Need trailer pics
wakeout
The reason I'm asking is I have a tri-hull boat and I don't think the trailer
is the right one for the boat. The trailer is a shoreline. I just need to get
an idea of how a trailer is set up for a tri-hull. When I'm ready to load
the boat on the trailer the bow drops below the bow stop, and have to
pick the bow up to fit in the stop. any help would be appreciated.
tashasdaddy
Re: Need trailer pics
trailer is too deep in the water.
redfury
Do you have a front roller for the keel? My trailer isn't set up completely the way I plan to have it once the boat is being used, but it's set up to support the boat even with the trailer and supported properly under the hull. I've pulled it off the ground with the tilt function of the trailer. You can see pictures of it in my links.
Trihulls can be a challenge to set up depending on the trailer type and the actual hull type.
