Need to verify NS50D coil resistance requirements
Willow Creek
I have a Nissan NS50D 50 hp 3 cylinder motor. I think it is a 1996. I believe my service manual might not be the correct one and would like verification of the coil resistance requirements. Exciter coil shows 174 to 236 ohms, the Trigger coil shows 167 to 225 ohms, the primary winding on the ignition coil shows 0.19 to 0.25 ohms, and the secondary winding on the ignition coil shows 3600 to 4800 ohms.
If you could help me verify these requirements it would be appreciated.
TOHATSU GURU
Re: Need to verify NS50D coil resistance requirements
Do you have the individual service manual for your engine or the service manual that covers the 3 and 4 cylinder models?
Willow Creek
You are correct. Wrong manual as this deals with 2 cyl 50 HP and 3 cyl 90 HP. I need the 3 cyl 50 D model. I have ordered a new manual for 3 and 4 cyl. Headed down to the boat this weekend (200 miles away) and I don't get there often. I guess I could test each component and see if they are close since the information appears to be top secret until the manual arrives.
TOHATSU GURU
You have to be a Cylon to be privy to the "secrets". I haven't seen you at any of the Cylon meetings that Pvanv and I go to so.....:)
