Need to replace rear motor mounts Merc 470
bart98stang
Greetings everyone! I hope your boating season, if started, is going well.
After about a month of trying to align my 470 with my MC-1 drive I gave up and had somebody come over and help me align it. Well he found that my rear motor mounts are bad which is why I could not get the tool to slide into the coupler. Should I buy the rubber mount only or should I get the kit which includes the rubber mount, bolt, nut, washer, fiber washer, and the lock washer? Also, using the attached picture I found in another thread I imagine the rubber mount is installed inside of the rear engine mount identified as part c? Thanks!
Bt Doctur
Re: Need to replace rear motor mounts Merc 470
old mount is pressed/burned out and new one is pressed/pulled in place.there are 2 types of mounts available.
the old style that still uses the doublewound washer and the new style that has a knurled bottom that does not use the double wound .
Might have something to trade too, will pm my cell.
