sebas54
- Jun 17, 2007
- 334
Hi I have a 1980 22' aquasport. I hit a rock and have been trying to fix the scraths and damge cause by the rock all day. I graind the boat for two days then vacumed the rest out. Today it was dry so I went ahead and applied marine tex and a sheet of fiberglass. All was going good and everything was drying, then i noticed it was dripping water. What should I do? I put a hole in the floor to see if there was any water an there was non. I put a heat lamp on it and am planning on using a epoxy stix on the outside of the hull. What can I use for the inside part of the hull?
Thanks for all the help.
