metalwizard
Thread starter- Joined
- Sep 13, 2010
- 411
I have a 73 arrowglass with 165 hp omc outdrive.
when I got it there were some Drive and tilt problems. had to change out the intermediate housing and some minor stuff. got it all taken care of.
Put the motor back in hooked up some water to her and Water is pouring out from under the int/exh manifold. I get in there with the flashlight and a freeze plug is missing. THis is odd because no leaks (that I new of ) before I pulled the motor.
So I pull the manifold put in a plug and fire it up again. STILL LEAKING (very minor compared to what it was)
I get the flashlight out. and I have a hairline crack about 1/2-1" below the head gasket in the block. AARRRRGH!!!
Ok the motor is old. so First off I am wondering if it was that way when I bought it and I got suckered, I only had it in the water once and got about a cup or two of water out when I pulled it out and pulled the plug. So I think it is possible it was bad beforehand.
Just a note I did drain the two petcocks on the side of the motor before it got really cold. But It is possible i was to late. and it's my fault. Either way. I got to do something.
My question. I have never owned a straight six. When you run them out of the water are they noisy? (i know nothing to do with my leak. i will get to that) I understand no muffler, so its going to be loud, but the motor itself seems loud to me.
Ok. if it's supposed to be quiet, It seems like i should just go with a new (used rebuilt etc) motor.
If I do that can I use a 250 Chevrolet CAR engine? (long block only not carb dist etc)
If so I heard I need a special head gasket, IS this true? is there anything else I need to make sure of or change to be Boat ready? or is this idea BAD..
When I talked to my wrecking yard they said they also have 292 Straight six motors. that should be the same externally. Dose that sound correct? and is this something I should or should NOT do? I cannot read the HP rating on the tag. it is just plain worn gone.
THe boat is a 73 Arrowglass Viper. 17.5" foot long. I don't know what else is needed to figure max HP..
Thanks in advance for your input. If any more info is needed I'll do my best.
