FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
If it's a square bore prop with the replacable hub you'll want to make sure the insert is seated properly and torque it down to 55 lbs. Check it every so often, make sure it stays tight so you don't split the insert.
