Need more performance...HELP
Brawne
Hi Everyone, I own a 1989 Cadorette 16.6 Ellite, 3.0 OMC...this boat has a very deep V-Hull and is generally a heavy boat. I am fine getting up to plain when it's a few people...but if I have 4 or 5 adults...it takes a long time to get to plain and seems to be lacking power. I am thiniing of ditching the alunimun prop, for a better performing stainless steel prop.
Does anyone have suggestions as to a solid performace prop that would have a better pitch and performance for my boat.
Thanks
steelespike
Re: Need more performance...HELP
Need your present prop size usually on the prop,also max rpm and speed.
Brawne
Thanks Steelespike, my challenge is that the prop is so worn that there are no visible markings at all on it. I would think that it is stock, so maybe my best bet is to research what prop came with my model, boat size and year.
steelespike
A prop shop can measure it for you.Without a prop size no way to know where to start.Do you have the present rpm and speed?
Based on the boat size my guess is it came with a 21 pitch.Of course we don't know if someone changed the prop at some point.
