Re: need model and info on my glastron
i have roughly $50 into this boat, and that includes the purchase of it and im pretty good with mechanical stuff and i am always working on stuff so i dont mind a little challenge...
That's kinda' the way you approach a Stringer project. No matter how nice you make it, the boat will never really sell for more than $2,000 (depending on where you are). Glastrons have a better following, so there's a little more "classic" boat juju behind you - but that doesn't count for much in trying to get back some of what you put in.
If it's about the challenge and fun of redoing an cool ole' boat, set a "don't spend more than" point and enjoy it as much as you can.
If it's truly about getting a boat and being on the water ... part this mug out, and spend $3,500 on something lake ready.
...quick question on what to do for running this outdrive setup out of water, how do you do it? i have ears but they will be pointless in a setup like this, is the only real answer dropping the outdrive in a barrel full of water?
Three ways to do it: 1.) Dunk it in a tub like you said above. The Stringer needs to be submerged to get water running (properly) through the impeller up into the engine. 2.) use the
HOSE ADAPTER if you have one. I didn't see it on your boat, but you can find 'em on ebay. 3.) Rig up
THIS GIG that Howard Sterndrive suggests (post #5 in the thread. It'll draw water down to the impeller. You can start the boat off a hose for a minute or so, but it can smoke an impeller fast if you're not careful. (your upper gear case is ALWAYS turning no matter if you're in gear ... the impeller is at the bottom of that unit)
when i was looking on ebay i was seeing people asking $750+ for just the lower section of the outdrive on these setups and $450 for the upper, and im sure a running motor is worth at least $750, it almost seems like i could stand to make a pretty penny off of parting it out but thats not my style, i like to keep the good old things together and running, i was just amazed at the prices.
I've bought a complete working drive for $400 and I've bought non working units for parts for as low as $25. It just takes looking. Generally what you find easily is expensive, mainly because the systems are getting more and more rare and sellers know it. It does take patience.
You may want to remove your drive and see how things look to be working. It's tough to test the lower off the boat, but you can do it. The upper is pretty easy to see if it's working. Taking the drive off is a 15 minute process for me - and I'm not very mechanical.
