Need lube advise
tkz
While I was at Cabelas yesterday, picked up a fluid extractor, for my engine oil and a pump for the lower lube change, figured I would get a few things in advance for winterizing. Also picked up two quarts of merc 90 w gear lube, the high performance. I had bought a 1990 Starcraft Heritage this year. 3.0 Alpha One. The lube was just under 20 bucks a quart, holy crap! Can I just use any 90 w gear lube and save a few bucks? The bottle reads anything else may damage, is this warning just to scare us numbers into buying merc products or is it something that needs be be followed? Just like Harley oil for the scooter? Appreciate any advise on this.
86 century
Ensign
Re: Need lube advise
Last I knew merc didn't make oil so someone else makes it and slaps mercruiser on the bottle and doubles the price.
Any high quality 80/90 will work just fine.
Bob_VT
Marine lube reduces scuffing and is designed to run in a wet condition.
Read this article http://bwbmag.com/output.cfm?id=1891729&sectionid=308
Walmart sells marine grade lube........ some of the VP lowers call for synthetic. Save a few bucks now and a lower unit is only $1300-1400 for a replacement. I use only marine lubes GL-5
NHGuy
True that, the regular gear oil is a no no. You did the right thing.
BTW it's almost impossible to extract cold engine oil. Warm it up (on muffs) before you suction it out of the motor.
nola mike
Sierra also makes merc knockoff lube for $10/qt. Although really, in the grand scheme of things not that much when you only need 1 qt once a year.
tpenfield
Since I only change gear lube every few years, I used the Merc/Quicksilver stuff. It is a pretty color and tastes much better than the generic stuff.
Bob_VT
Hmmmm on french toast, pancakes and over ice cream too!! :p
tkz
Thanks for the info, read article also. Suppose I'll just keep what I bought then. It is labeled Mercruiser lower lube 90 w. Also I am assuming that there are oring on the plugs, do you guys replace them every fluid change?
NHGuy
Just have a package handy, you don't want to drop your lube because the o ring disappeared or fell off. A little pack costs next to nothing.
ktbarrentine
Might be semantics, but those are actually gaskets. O-rings (typically rubber composition) dont work too well in that application. Just sayin':D (not because of the composition interaction....but because you have to get those plugs good-n-tight on the gaskets....rubber will extrude....OK...I talk too much)
BoatDrinksQ5
from what i have in my parts lists - they are described as 'Fiber Gaskets' , part 19183
my question - can you and is there any benefit to putting a magnetic screw in the top vent? So basically storing your spare there :)
