Need help!!
Newtont86
hello all. I’m working on a 1982 Deck Boat Deckette 2. Most of the wires have been cut for whatever reason. My guess, things started failing and instead of replacing components, just cut wires and bypass.
I can fix it, but I need a wiring schematic. Does anyone know where I can locate one for this boat??
Any help would be mucho appreciated.
Good luck. Boat wiring is very generic and there are many diagrams in this forum. Wiring for the engine and harness going up to the controls will be in the service manual specific to your engine.
Newtont86
No manual. That’s the problem. I’ve noticed that the wiring is generic. I don’t really want to redo everything, but if I can reuse the wiring, I may go ahead and do that. This only has one battery, is that typical? Or should there be two?
most boat companies do not make wiring diagrams. they have the wiring from the motor which covers the helm to the motor, then they add lights and horn. look at the manual for what ever motor you have, that will cover gauges, start circuit and motor.
if there was a diagram, it was probably sketched on the shop floor or a notebook in the shop in the 80's
however all the wiring should follow the standard colors
as for the battery question. most boats come with one, some are rigged with a battery switch and more than one.
American Boat and Yacht Council Standards
BlackGroundNegative / Neutral Main Return
Blue-StripeTilt up and or trim outTilt and or trim circuits
BrownAlternator Charge LightGenerator Terminal or Alternator Auxiliary Terminal to Regulator
Generator ArmatureGenerator Armature to Regulator
PumpsCircuit Breaker or Switch to Pumps
Brown w/YellowBilge BlowersCircuit Breaker or Switch to Blower
Dark BlueCabin & InstrumentCircuit Breaker or Switch to Lights
Green or Green w/Yellow StripeBonding SystemGrounding Wires (if insulated)
Green StripeTilt down and/or trim inTilt and or trim circuits
GreyNavigation LightsCircuit Breaker or Switch to Lights
TachometerTachometer Sender to Gauge
Lt. BlueOil PressureOil Pressure Sender to Gauge
OrangeAccessory FeedAmmeter to Alternator or Generator
Common FeedDistribution Panel to Accessory Switch
FeedAccessory Circuit Breakers or Switches
PinkFuel GaugeFuel Gauge Sender to Gauge
PurpleIgnitionIgnition Switch to Coil & Electrical Instrument
Instrument FeedDistribution Panel Electrical Instruments
RedInstrument FeedDistribution Panel to Electrical Instruments
Power FeedsPositive Main Power (particularly un-fused)
TanWater temperatureWater temperature sender to gauge
YellowGenerator FieldGenerator to Regulator Field Terminal
Yellow w/RedStarting CircuitStarting Switch to Solenoid
legalfee
It would be helpful to let us know the motor year, hp, and model.
