Need help with power trim
TMW440
I have a 1997 50hp Johnson, the power trim is slow and weal when tilting upward.
Will Bark
Re: Need help with power trim
Once you get it up check the fluid level in the resivoir you may just be low. Good luck
Chris1956
Check the electrical connections to the relays and switches.
D
DJ
Guest
1. Raise the engine, all the way.
2. Block it up. Use anything to keep it up-SAFELY.
3. Remove the "Fill" screw on the power tilt and add fluid.
4. Cycle the system up/down. Repeat.
BE CAREFUL about cycling up/down. You can overheat the trim motor.
