Need help with power loss 1997 50TRV
pro470
The motor has been running great this spring, have put roughly 30 gals. of fuel through it . I was out the other day, completed a 20 mile crossing of the bay, when I came off plane the engine stalled. Started fine and idled fine, got back up on plain and ran for another five minute then gradually lost power over 30 seconds, I brought the boat off plain, the engine idled fine. Then I could start out again and go another 1/2 mile then I would loose power again.This happened a few times, then the engine ran fine for 40 minutes, when I got close to shore I let off on the throttle and tried to reapply throttle and had loss of power again.
The motor was running at 120f and 25psi water pressure. I tried switching fuel tank and line and also tried pumping the gas line during power loss with no affect. I have cleaned the fuel filter on the motor, drained carbs, the plugs look the same.
The power loss it very smooth and gradual no vibration at all.
Where should I start, any help would be greatly appreciated.
Thanks....
pro470
Re: Need help with power loss 1997 50TRV
compression is 118,120,118
It fires right up with the ear muffs.
pro470
Two week ago I purchased 10 gallons of fuel from a station, the first five gallon I added to my tank I noticed the the fuel was yellow, before my last trip I added the another five gallons. My last trip I used 8 gallons instead of the usual 5 gallons. Anyway I changed the plugs and added 10 gallons of 91 to my 12 gal tank. Seafoam is not available in this area.
Hope this works..
pro470
Had the same problem today, slow loss of rpms. I thought it might be a loose throttle cable, so I removed the motor cover and applied full throttle the motor ran ok for 2 minutes then instead of loosing rpm I gained rpm. The rpm loss seems to like to happen after the motor has been run then stopped. Could it be heat building up under the cowl after I stop. I usually stop and fish for a half hour or so. The motor has been running at 122F water temp is 65F. When I stop the motor will heat up to 140F or so. Could it be some part like a coil failing from heat.
Any ideas......
pro470
Had another look at the motor, the bottom of the three plugs is covered in a thick salt crust, the plug has about 1 hour of run time on it. So is the head gasket gone, and would this cause the problem.
pro470
Replaced head and water jacket gaskets. Same problem today.
Any ideas, Fuel-ignition..........
pro470
Dealer says cdi is giving reading different then the book. $800.00 plus tax for a new one, they will not take the new one back if it's not the fix.
Need help with this one, that alot of cash to throw away on a part I do not need.
Ray Neudecker
Easiest way to confirm CDI problem is to take a timing light with you and check fire when it acts up. There have been some issues with the 3 cyl CDI.
