Need help with decking
Jrcrmoore
I'm restoring a pontoon boat, and yesterday I stripped it down to the aluminum rails. Already spent the money on 5/4x6" treated decking boards thinking that would look great, and then researched afterwards and found out that treated wood and decking shouldn't touch. What would be a good, cheap barrier that I can use?
jbcurt00
Return the 5/4 deck boards and get plywood.
It is worse were the pressure treated lumber is in contact w aluminum, but the corrosion also occurs in non-contact areas where water has leached the chemicals out of the wood and collected elsewhere....
Grandad
I think too you'll have less corner flexing on waves with plywood than with individual boards, if that's a concern for your design. - Grandad
Woodonglass
Honorary Supreme Mariner
I'm in TOTAL agreement with the rest of the members. 3/4" Exterior Grade plywood would be your best bet. If you want to seal it to get more longevity use this... 2 gallons should be enuf for a Pontoon Deck. so that means 2 quarts of BLO a gallon of Mineral Spirits and a Gallon of Polyurethane. If you seal the wood with this formula and let it cure for a week and then install your carpeting or vinyl decking taking care to predrill and seal any holes you put in the deck when installing all hardware, seats, railings, consoles etc... your deck will last a good long time. As the instructions state the edges of the wood are the most important areas so really soak em good!!!!
