Silvertip
Honorary Supreme Mariner
- Sep 22, 2003
- 28,772
Re: Need help with boat gages
If you follow what daisy chaining is and have done what we told you then there is nothing else left to deal with. So I will try one more time. The purple wire from the control box goes to the +12 volt terminal (the "I" terminal) on the first gauge in the string. It doesn't matter which one. Obviously the first gauge would be the one farthest to the right (closest to the control box) is it not? You then run a wire from that terminal to the +12 volt terminal on the next gauge, then the next. At the end of the line there will no more wires. The black wire goes to the ground terminal on the first gauge. Then that terminal gets jumpered to the next gauge, and the next and the next. What you did with the gauges internal light connection is puzzling but here is what needs to happen. That light circuit has nothing to do with the ENGINE harness because it is part of the BOAT harness. Daisy chain the light connection just like you did +12 volts and ground. The "L" connection on the first gauge gets connected to the NAV/ANCOR light switch. It connects to the NAV side of the switch -- not the power side or the lights in the gauges will be on all the time. Connect it to the side of the switch that turns on BOTH the bow and stern lights. At this point the only connections remaining are the FUEL SENDER, TEMP SENDER, TRIM SENDER, TACH SEND. Tach send ("S" terminal) gets the gray wire. If your engine doesn't have a TEMP SENDER (different from a TEMP SWITCH) then the temp gauge will not work. You need to verify if there is a temp "SENDER" on this engine. The wire is typically brown/tan. The FUEL SENDER wire is typically pink. All of those get connected to the "S" terminal of the applicable gauge. You also say you took pictures. So post them. At this point we are 19 posts into trying to help and we are no closer to a solution than when we started.
