Need help with 1968 Evinrude 6hp Fisherman
jacobcraft7
Hey guys. I have the mentioned engine and it says the original sparkplugs are champion j4j. Can I supplement them with a different brand/number? Thanks for your feedback
Daviet
Re: Need help with 1968 Evinrude 6hp Fisherman
Those engines were designed to use champion plugs, that is what I would use.
Daviet
Oh, by the way, welcome to the forum.
jacobcraft7
Thanks Sir! I got the motor and it hadn't been ran in 20+ years. 9 cranks and she fired up but the impellar was broke so I dogged it off. I just ordered a new housing and the works so I think I am good with that. It would probably be a good idea to clean the carburetor wouldn't ya say?
bonzoscott
Should have ordered the carb kit with the pump, save on shipping. Try it out after the pump and see.
Daviet
After you get the pump fixed, try running it and see how it runs. After sitting that long, I wouldn't be surprised if you will need to overhaul the carb.
jacobcraft7
Thanks!!! Also I know this is probably a dumb question but what size boat would be good for this 6 hp?
Daviet
All depends what you are trying to do. Around here I have seen a 6hp on everything from a 10 ft john boat to a 16 ft fishing boat.
jacobcraft7
I mainly want to use it on the river, backwater lakes, creeks. No lakes
emckelvy
BTW, the Champion J4C spark plug is the replacement for the old J4J. The only difference is the "C" which stands for a Copper core.
The Stock Number for the J4C plug is 825, if the parts counter person wants to know. I usually get mine from the local NAPA store, they have no problem getting the various marine-use plugs.
Champion J4c - Champion Spark Plug ( #825) @ MarineEngine.com
HTH...........ed
