So since he cleaned it up, and we further assume that means he honed it to clean (take material out) it so it could be measured, and it still measures only 3.530, we can be assured that it was too tight to start with. Actually its still on the tight side. It should be at a finished bore size of 3.5305" minimum. It almost sounds like an automotive shop did the boring.<br /><br />Thats a number for an OMC/BRP piston. The piston and ring part number is 396588. Told ya it wasnt a Wiseco.The block has been inspected and cleaned up by the original machinist.
Consistancy in the size and spacing of the verticle scores...this is consistant with glass beads, fines that were not cleaned out properly after finish hone, etc...<br />Here's a thought for ya on piston size...If the shop doing the machine work asks for the piston to insure a proper fit, find another shop, period. These pistons are made to fit over-bore sizes as stated,"OVER BORE SIZE", ie, .020, .030, etc...this is the size of the BORE OVER STANDARD. simply put, if we know our std bore was 3.500 and will require "20 over" pistons, the block is bored to 3.5200-3.5205.<br />The shop has NO WAY to tell what the expansion rate of the piston is, and has no reason to "Fit" the piston to the cylinder unless he is not able to properly measure a bore, in which case he is just "being consistant", whether tight or loose, he does not know...only the piston manufacturer knows, and that number changes with bore size, so all they want you to do is bore to whatever size over std is required.<br />Sorry for the ranting....this subject of "fitting pistons" just kills me..Rodbolt says "looks like honing debris left in cyl when reassembled".........how exactly can you see that??<br />
A lot lower rpm than what? Dont get confused on the rpm issue. Setting that motor up at the lower rpm's increases combustion temps which promote coking. Thats what we call "lugging" the motor. Its working really hard. Too hard. Its not supposed to be set up that way. Setting it up correctly helps keep the combustion temps in line with design parameters.I can see the coking happening, especially since outbaords run a lot lower rpm.
