Re: Need help on piston failure
Here is an interesting thought! You are running the engine at 4000 RPM. In mechanic's, there is a point called harmonic impalance. At this point, rotating part's stop spinning around there center of mass, and start spinning around there center of gravity. When running an outboard in a test tank with a timing light held on the flywheel, you will see the flywheel start to take on a ripple, like the wave in a pond, when it takes on this imbalance. At this point, resonance is at the highest, and every thing start's to shake, and vibrate. If you listen closely, you can here the engine take on this sound as it goes through this transition. At 4000 rpm, you are probably running at this stage. Run the engine at it's proper RPM range, or at it's cruise throttle range. Those piston's could be from an engine that has been heavely lugged, or run at this stage of imbalance.
