Need help on a 1959 johnson seahorse 3
bsorrells
I'm having trouble finding the correct fuel mixture I've tried to read up on it but i still don't know if its 50:1 or 24:1. its also leaking oil from the bottom of the shaft and i don't know where to get the gaskets or what else the problem could be
bsorrells
Re: Need help on a 1959 johnson seahorse 3
Thanks for the info so quick I just wanted to make sure it's running right for fishing. Any guess on why it's leaking oil... Is that a common problem?
cr2k
Anything can be a common problem from age, useage and maintenance issues.
F_R
Honorary Supreme Mariner
The oil that you put in the gas goes through the engine and out the exhaust. That may be what you are seeing, especially if you are running it in a bucket. In any case, it is perfectly normal.
But check the gear oil in the lower unit, just to make sure that is ok. It is a totally different oil.
