NEED HELP on 89 110 lower unit rebuild
ole farmer
I am resealing the lower unit and the two seal's right below the water pump I am in need of advice on. My kit came with two seals of the same outer size but one has a thicker rubber than the other. I didn't see a differance on disasembly but I realy didn;t look. should the heavier seal be installed to keep oil in or water out because of the water pump above???? Thank You
Fed
Re: NEED HELP on 89 110 lower unit rebuild
If they have part #s on them the brp website shows #0329922 as top and #0329923 as bottom, other than that I'm no help at all.
