Do the usual spark and compression checks and see what you have (use an adjustable open air spark tester, and look for about 3/8" sharp spark.) If spark is weak, figure on ignition work. If the motor is new to you, should pull the flywheel and check the ignition coils. Replace them if casings are cracked. Clean and adjust points. Proper plugs are probably Champion J4C gapped to .030, but should check. Replace the impeller.
Fresh fuel (50:1 OK). If it's stubborn when cold (slow to warm up), think about replacing the t.stat -- or make sure it has one.
