Need help ID'ing what impeller i need.
legoman67
'74 mercruiser 255MIE Auxillary water pump, i do not believe its the factory auxiliary pump though, i found 3 numbers on it
on the main casing:
46
73823
and on the cap for the impeller access:
59155
I cant seem to find anything that matches these numbers:confused:
EDIT: WOOPS POSTED IN WRONG SECTION, MOVE TO I/O discussion?
jerryjerry05
Re: Need help ID'ing what impeller i need.
An auxillary pump where and what does it supply water to.
Any serial# anywhere on the motor or transom/drive?Ford or Chevy Block?
Look at this pic.J
59362A 1 Mercury part# I think.
