Need help identifying and sourcing a missing component
GeechySC
Hello all,
Relative newb here, need some help with a part. Just wrapping up a water pump job on a new to be 40hp Evinrude, 1988 model E40ELCCS w/ remote controls. I found a gasket laying in the bottom of the gear case exhaust channel that got me looking, and I believe I am missing a part. I have a few pictures noted that might help, a photo of the gear case with the area circled where I believe I'm missing the part, a picture from the OMC manual showing the part I think I'm missing, and a parts diagram from iboats with the item I think I need circled (item #60). The pic of the gear case is all I have, and I believe there should be something approximately 4-5" tall sticking up from this piece that would link up with the exhaust outlet in the midsection - right now, it's just a big gap. Problem is I can't find this item #60 on any of the parts lists to identify or purchase it. Does anyone have any ideas about this thing? What is it called, is it necessary, where can I find one? I'm thinking it must be obsolete if not in the parts lists, but thought I would consult the brain trust before calling no glory. I believe strongly in trying to maintain my motor the way it was designed; not sure if this is a critical component but figure it must have had a reason for being in there. Not above trying to fab something up if that's my only option. Any thoughts on an appropriate material if I need to go this way? Thanks in advance for any help you can give, I'm really at a loss with this one.
GA_Boater
Look up inside the midsection. I think you will find the missing exhaust tube.
Vic.S
Go to the Official BRP parts website at http://epc.brp.com/Index.aspx?lang=E...4-e57fd0f92843
locate your motor by make, year , HP and model number.
Look at the "gearcase" and and "midsection" parts lists and you will be able to identify all the parts in which you are interested and find the parts numbers.
I would consult your dealer if I were you regarding the part labelled #60
GeechySC
GA_Boater thanks and that would have made my day, but I don't think it's the case. Took a picture up into there (included), it's right at 5" from the top of the exhaust gasket on top of the gear case to the exhaust flange up in the midsection shown in the pic. There is also a different shape to the opening. Maybe this gear case isn't original to the engine, I really don't know.
Vic.S thanks for the link, I hadn't stumbled into that section of the BRP website just yet, very helpful. Their parts lists jumps from item#59 to #61 as well, but shows that item #60 in the diagram. On the midsection and gearcase diagrams I do not see a riser anywhere,but this think obviously had something in there otherwise there would be no need for gaskets. Only place I've seen it is in the image in the OMC factory service manual. I will check in with my dealer tomorrow morning.
Thanks for the feedback folks.
GA_Boater
It was a hope,.Geechy. The tube sticks up there on some motors.
GeechySC
So I discussed this part with my dealer today, and he basically told me that they have no idea about what that part is, and that getting some support from BRP would be a lost cause. He let me speak to their mechanic who said that if its been running alright without it to just keep on rolling, which is what I'll do. Wanted to close the loop with you all and thank you for your feedback.
