Need help identifying a Boat
tl7983
Hi,
I'm looking to identify this boat. I need to know what year and model it is. I'm considering it for parts for my '88 Bayliner Capri 3.0 OMC. Outdrive looks similar. Owner has no paperwork.
Any help would be greatly appreciated.
Thanks,
Tim
CheapboatKev
Re: Need help identifying a Boat
see if you can go look at her and find the manuf tag, maybe up near the console or stern (?)
If you get all the manuf codes-serial numbers hull ID #s theres guys here that can de-code and translate..Ya know those guys, they schmart ones..def not me
BTW
WELCOME ABOARD!
jsturkie
I think it's a '87-89 bayliner Capri 19.5. Not sure of the drive line because they just moved form Volvo lines after '86. What parts do you need? This boat looks like it needs its rest!
tashasdaddy
there should be model & serial # on outdrive.
tl7983
Thanks for your help. I believe it's an 89 (compared a lot of pictures on the web). Bayliner sure makes a lot of models.
OK. Are all 3.0 OMC outdrives compatible for swapping?
Thanks,
Tim
