need help identifying 86 Volvo penta out drive
notordinary
Hi, I'm hoping someone can help me with out drive questions.
I purchased boat without motor. It is an 86 sun runner 210 with a sp grey colored outdrive. Sp-e? It has a large bullet on back of lower unit unlike any other drives I have seen even dp's and sx's?
I know my drive is an SP drive but cannot find any drives on eBay or anywhere else to match mine.
It has a symmetrical Line on both sides running in a half circle from the drain plug up to the back of lower unit. Looks like a crack to me but buddy says it is just a mold mark since they both are the same??
Re: need help identifying 86 Volvo penta out drive
take a pic a bit farther back to get the whole drive in the pic. your outdrive has been modified with a nose cone. you can see the outline where the epoxy is cracking along the edge of the modification.
do you have a trim gauge?
you should also have a serial number on the upper gear box just in front where the steering helmet pin is.
K-2
serial tag.jpg Click to enlarge.
Tag should be there where little red arrow is pointing , hard to see if out drive is tilted all the way up.
notordinary
OK I'll get pictures tomorrow.
Thank you everyone for answering so prompt.
jerryjerry05
What motors in the boat?
Looks like a SPA or SPA-1
From a 230A/230B Or 250A/250B
AQ311A, AQ311B - 7743550
notordinary
There was no motor in the boat when I purchased it.
Getting better pics of outdtrive in a bit.
That nose cone is exactly What's on there.
I'd never seen one before. Thank you. Post pics in just a bit.
K-2
As the OP stated, the color is SP-E..but is some of the paint peeling? Maybe a older model painted the SP-E color?
SP-A ,A1 , A2,,(is there a SP-B ?)have 18MM hinge pins, from SP-C on they went to a bigger diameter hinge pins .
