Need help finding a new duoprop
Pete1burn
1994 Larson LXi 194, Volvo Penta 4.3GS, model 4111506964. I grazed the bottom a couple weeks ago and the prop has some nicks and slight bends in it. Boater friend said it was fine, but everyone here says that any damage will vibrate the outdrive, so I figure better safe than sorry.
I couldn't find any obvious size or pitch numbers on the prop, but here is what I managed to figure out.
Inside prop:
H&H 204761
B88548xx (couldn't read the last two numbers.)
1659W
Outside prop:
H&H 204762
B8854837
Any help would be appreciated. Thanks.
Maclin
Re: Need help finding a new duoprop
You can get them repaired and not necessarily have to buy new ones unless you are going for spares.
I send mine to Midwest Propeller in Olathe, KS. I used to live close to them but their reputation is why I used them. There are others also, you may have a local option.
As far as replacements, a B7 set would be close enough to what you have if are in a pinch.
