Need Help Choosing a New Prop
Bulbash
Boat: Bayliner Capri 1750 with OMC 2.3 Cobra
Currently I have 3 blade 13.5 x 15 prop installed on it, it does give me a good hole shot but not much of top speed around 30 -35mph. RPM's stay in recommended range (5200 - 5400).
Now I'm planning to upgrade to 4 blade prop, and question is which pitch should I go with? Should I stay with 15 pitch or should I go to 17. As far as I understand, my hole shot will improve, but top speed will decrease so would it make sense to increase to 17 to keep same top speed or no?
dazk14
Ensign
Re: Need Help Choosing a New Prop
What are you trying to "fix" with the new propeller.
Levinz11
Going to a 4 blade will help your holeshot... usually. It will also LOWER your top speed a few MPH... usually. I use a 4 blade because I am always pulling something: tube, knee board, wakeboard, etc. For watersports a 4 blade is great. When you go from 3 blades to 4, you need to DROP an inch of pitch or 2.
If your goal is more speed keep the 3 blade.
steelespike
I'm guessing that when new it probably had a 17" prop turning around 5400 and speeds about 38.
But I think she has gotten tired.I don't think there is anyplace to go for more speed.
You might be sure the throttle opens all the way.Check/set the timing and be sure it advances as it should.
A compression check may tell you about the motor.
The same prop in stainless might help a little
Bulbash
Boat runs great and has a newly rebuild engine...
What I'm trying to find out is, what will happen if I go from 15 pitch 3 blade prop to 17pitch 4 blade...
BoatDrinksQ5
from my limited knowledge adding another blade and increasing pitch will make the RPM's change outside of the recommended range (likely anyhow)
Typical practice assuming existing 3-blade falls in proper RPM range (your case), then you drop pitch with a 4blade.
Levinz11
You will lose about 600 RPM's at WOT and speed as well.
