CamaroMan
Thread starter- Joined
- Mar 18, 2016
- 330
Sn is 628*** 200 black max, 1985 iirc- comp is fine on all 6, 120 across the board..
Intermittent spark across most cyls, but cyl 4 is awful, on and off, fluttering about-
I double checked the kill switch (yellow/black wires removed made no difference)
I also disconnected the reg/rect (no difference).
Carbs just rebuilt, max timing set at 20 degrees cranking, idles around 6 degrees ATDC-
Huge puffs of smoke on startup and a really nasty eye burning smell (unburned fuel). I mixed a fresh mix of 50:1 for testing. Battery fully charged and all connections in good shape.
Here are the results.. intermittent spark across multiple banks but #4 is the worst..
DVA: (motor idling)
2-4-6 (outer switch box/YELLOW sleeve):
purple to gnd: 4.3v
white to gnd: 15v *** this ones the worst, spark is on and off
brown to gnd: 4.3v
Blue (low speed) to gnd: 314v
Red to gnd (high speed): 198v
1-3-5 (inner switch box/ BLACK sleeve):
purple to gnd: 5v
white to gnd: 4v
brown to gnd: 6v
Blue (low speed) to gnd: 266v
Red to gnd (high speed): 203v
Stator (2 yellow wires): 92v (at idle)
Bias circuits (wire disconnected and measured terminal to ground):
Both: 960 ohms (ill have to recheck 2moro to make sure the k or M wasnt appearing, it was dark with a headlight), "should" be 9000 or 15000 depending on make ive read.. so IF this is outside those specs could the switch boxed also be bad?
DVA: (motor idling)
purple to gnd: 4.3v
brown to gnd: 4.3v
purple to gnd: 5v
white to gnd: 4v
brown to gnd: 6v
