Need help! 1978 Johnson 115 outboard.
Ambern109
Hello everyone! Ok so we are sorta new to the whole boating thing. I have inherited a 1978 Mark twain boat from my grandfather. It has a 1978 Johnson 115hp outboard. It last ran in 2008. We brought it home and flushed what was left in the motor from being stored. After replacing the fuel lines, fuel tank, battery, cleaning the carb, checking fuel filter, and the lower unit fluid, We put the muffs on. Took it a moment but it finally cranked. Sounded strong once she did. She ran for a few mins and then cut off. We tried cranking it again and she would turn over but not crank. Come to find out the battery wasn't strong enough. Well after charging the battery that night we tried the next morning and she ran strong. But here is our dilemma. After about 3-5 minutes of running The right side cylinders stay pretty cool. They don't get to warm. But the left side gets pretty hot. Not unbearable to the touch but it is a significant amount of heat compared to the other side. We checked thermostats and they are fine. We are going to attempt to check and see if the impeller needs replacing. I'm sure it does since the boat last ran in 08' but is there anything else we can check? My husband is pretty mechanically inclined when it comes to vehicles. The boat part is new to us. Any insight to this would help us out tremendously! Also when we cranked the boat the prop has exhaust coming out of it. But the last time we tried to crank it there was nothing coming out. We didn't let it run long because we didn't want to ruin anything. So any help would be great. Once again we are new to the boat scene so please go easy on us! Thanks!
Honorary Supreme Mariner
When the motor is running / turning the exhaust will come out the prop.------You may want to look into an item called a water deflector / diverter on this motor.------They are found when removing the cylinder head.-----They can block water flow in the one side.------But the motor may also be running on just 2 cylinders and you should check for strong spark on all 4 leads.-----It will run quite nicely on a hose with just 2 cylinders firing !
'82Glastron
It might be because of the muffs. You may not be getting enough water to the block. Try running in a bucket or better yet in the lake.
Ambern109
Thanks for the input! When we ran it on the muffs it didn't seem to run as hot. We put it in a bucket and that's when we really noticed a difference in the temperature. And that's when it quit blowing the exhaust out of the prop. It was coming out at first because the water was bubbling and then all of a sudden it quit. It started doing it sporadically. Blowing then nothing. It was weird.
Racerone- with this deflector, in order to get to it would we have to take the cylinders apart? My husband didn't really want to tear into them if possible. But if that's something we need to check then we will.
Bosunsmate
you need the bucket to be filled with water almost halfway up the leg otherwise itl just suck air. The pump sits much higher than the anti cavitation plate. Muffs push water up there but in a barrel the water level must get up there as these pumps dont suck. At high speed in the water when your boats moving fast, water is pushed up there and at idle when the boat slows and sinks the stern goes deep in the water and the water level rises back up above the pump.
Ambern109
Bosunsmate- you're saying maybe we just didn't have the water high enough, correct? The barrel was only high enough to cover the intake at the bottom and the entire prop. But not much higher. We will give it a try this evening with a taller barrel and more water. Hopefully that's all it is! Thank you for your input!!
Bosunsmate
Yes, only covering the prop and intake will never ever ever ever or ever work. Go about two thirds above the cavitiation plate, the metal fin bit above the prop.
Ambern109
Ok. We tried it with raised water level. The boat actually ran a little longer this time. One side was running about 119 and the other side was at 93. Is that normal to have that much of a difference in the degree?
