Ambern109
Thread starter- Joined
- Jun 17, 2015
- 8
Hello everyone! Ok so we are sorta new to the whole boating thing. I have inherited a 1978 Mark twain boat from my grandfather. It has a 1978 Johnson 115hp outboard. It last ran in 2008. We brought it home and flushed what was left in the motor from being stored. After replacing the fuel lines, fuel tank, battery, cleaning the carb, checking fuel filter, and the lower unit fluid, We put the muffs on. Took it a moment but it finally cranked. Sounded strong once she did. She ran for a few mins and then cut off. We tried cranking it again and she would turn over but not crank. Come to find out the battery wasn't strong enough. Well after charging the battery that night we tried the next morning and she ran strong. But here is our dilemma. After about 3-5 minutes of running The right side cylinders stay pretty cool. They don't get to warm. But the left side gets pretty hot. Not unbearable to the touch but it is a significant amount of heat compared to the other side. We checked thermostats and they are fine. We are going to attempt to check and see if the impeller needs replacing. I'm sure it does since the boat last ran in 08' but is there anything else we can check? My husband is pretty mechanically inclined when it comes to vehicles. The boat part is new to us. Any insight to this would help us out tremendously! Also when we cranked the boat the prop has exhaust coming out of it. But the last time we tried to crank it there was nothing coming out. We didn't let it run long because we didn't want to ruin anything. So any help would be great. Once again we are new to the boat scene so please go easy on us! Thanks!
