I have a 1985 Evinrude 235. I took my boat out 2 days ago with this motor for the first time. I had run it a few times with earmuffs.. Didn't notice any problems. New thermostats and good telltale.
I would like to ask some advice about this problem before I haul it over to a shop.
The motor starts fine with a couple bumps of the enritchener and idles fine too. Problem is taking off, and it boggs out like its fuel starved. It seems to bog before I can get up on plane and I have to keep pulling the throttle back down to idle to keep from stalling it, so mid range I suppose. I think these carbs have 3 ranges, Idle, Mid and High..
Anyways, After trying to get up rpms several times, I noticed that when it was bogging that if I bump the enritchener once or twice, it cured the bog and it gets up and goes like gangbusters.
Actually, after going around the lake at 65 or faster, I notice that I can come back to idle and punch it up to high rpms without any bog or need to use enritchener, like the problem went away.
But after I shut the motor off for about a half hour to eat some lunch, when I start it up and try to take off its the same problem.. Its funny, almost like the motor's not warmed up...
I have changed all of the small rubber lines that go between the carbs, used sea foam, etc.
I am running a marine electric fuel pump that puts out a steady 3 pounds of pressure.
I was able to check my fuel pressure gauge 'when it was bogging' and noticed I had good fuel pressure.
