need a new water drain quick release fitting. cant find.
fast48car
it is a plastic fitting with half inch pipe thread on one end. has two quick release male nipples where two blue hoses plug on. tried to post a picture but it isn't working.
Fun Times
Re: need a new water drain quick release fitting. cant find.
Hi there, welcome to iboats! We're going to need a bit more information from you to try and help. What is it you are working on the engine or the boat?
Where/what does the fitting connect to?
We will also need the model and year of what you are working on and if it's the engine, the engine serial number may help as well. Thanks.:)
JerseyBoater
fast48car
I have a 2004 bay liner with a 3.0 mercruiser. Yes the pic above is the exact piece I need.
Ayuh,... Welcome Aboard,.... That piece is available from yer local Mercruiser Dealer, or any of the on-line Mercruiser Parts Dealers,...
I believe it's a Mercruiser only part,...
Bt Doctur
And if not available just replace it with brass plugs
