Need a new block!!! 1990 fourwinns 4.3
Captaindillon
I have a 1990 fourwinns 195
block number is 10172756
4.3 non vortec
what block will work? My heads are okay just my block is shot help!!!
DarrinT
Somewhere in the Mercruiser forum I read that the 4.3 out of an Astro van with do the job if you switch everything from your marine engine onto the truck block. The big deal seems to be that marine engines need hardened cranks journals etc. so they can run WOT all day . Its my understanding that the truck versions have the hardening to deal with the towing chores.
Do a search there and it should pop right out.
Scott06
This should run through what years are interchangeable. you may want to consider getting a newer vortec long block either as a reman complete base engine or from a truck at a wrecking yard
